Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Modell A1136 mit 30, 60, oder 80 GB Festplatte / Front aus schwarzem oder weißem Kunststoff.
910 Fragen Alle anzeigen
No Playback Sound on 5G iPod
Went to play music this morning, and I get no sound. When I turn up the volume, I can hear the clicks through my earbuds, even the slight 'hiss' typical of the volume up too loud, and the amp pop when turning on/off.
I see the music playing on the screen, and can navigate the menus normally.
I tried hard (Click+Menu) and soft (Reset Settings) resets.
Is there another measure I can try, or is this a logic board issue?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
SPAR DIR DAS UPGRADE
Mach dein iPhone so gut wie neu mit unseren Fix Kits.
Jetzt entdecken
Jetzt entdecken
1 Antwort
Hilfreichste Antwort
Scott Kolesar, check your headphone port and make sure it is not stuck. Insert and remove the headphone a couple of times in succession. If that does not work you may want to consider changing it. Use these guides to work on your iPod. Worst case scenario, you are having issues with the audio IC. This particular model has a problem with an IC on the logic board. You can try and see if you get sounds by applying some pressure to the right lower side of the ipod, almost between the click wheel and the bottom corner. Here is a forum that explains that http://discussions.apple.com/thread.jspa... and check for a posting by IPOD_wrecker. If that is happening to you there are only a couple of options. New logic board fro about $50 on eBay and other places, reflow your old logic board or you can try what warnergt did on http://forums.macnn.com/103/ipod-iphone-... it is kind of crude but it does seem to work.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Scott Kolesar wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 95
