Zum Hauptinhalt wechseln
A high-end smartphone in the HTC One series featuring Beats audio, released in spring 2012.
19 Fragen Alle anzeigen
Phone will not turn on after update
I have an HTC one S that turned off during an update. It turns on but turns off right after the HTC screen. Do I need a new motherboard?
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Hi,
First try to do a Factory reset (wipe data/factory reset). To enter in the HBOOT menu, remove the battery for around 5s and put it back. Pres and hold the Volume Down button and the Power button at the same time.
If this not help you, you can change the phone firmware from the PC using correct RUU. RUU is a windows program including stock ROM for your mobile. This program will restore your phone to a factory state.
Regards.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Luke wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 511
