Zum Hauptinhalt wechseln
Die Wi-Fi Version des iPad Air mit der Modellnummer A1474 ist in Space Grau und Silber erhältlich. Sie enthält einen A7 Prozessor und ist mit 16, 32, 64 oder 128 GB Speicherkapazität erhältlich.
311 Fragen Alle anzeigen
The smart case is locking the iPad when it touches the back?
I completed an iPad digitiser replacement, the smart case now locks the device when placed on top of the device, as normal. However, it also locks when folded behind and contacts the rear. I've opened up the iPad again, but I can't identify the magnets or find a solution.
I also can't find anyone else with this issue, any help would be appreciated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
6 Antworten
Gewählte Lösung
You smart case magnets are probobly to strong I would just turn the feature off on the iPad
War diese Antwort hilfreich?
Bewertung 1
Kommentare:
Thanks for this. Not quite perfect, but it'll do.
von
Turning it off is NOT a valid solution. Smh
von
Same problem here: after a replacement the cover turns off the iPad from the back, not on the front
Bewertung 1
Same thing happens to me. I thought maybe I pinched the ribbon cables. But without that case it all,works fine.
Bewertung 1
This happens when you don't use a genuine home button, it locks when the smart case is on back or front. Add the original or genuine home button (the ones that come with replacement air screens tend to be copies) and the problem will go away
Bewertung 1
I was in class and then my iPad Air just attached to the desk and the desk is metal and there is a magnet I think in the iPad and the iPad just attraks and it’s just the sid across the camera
Bewertung 1
I have an original Apple Smart Case and never experienced this.
Than i cracked my screen and went for a replacement.
Now I have ghost touches and this magnet thing.
The question I have is the guy changed the digitizer glass so what can he have moved to do this?
Bewertung 0
Antwort hinzufügen
transbaconist wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 14
Insgesamt: 1,760
