Zum Hauptinhalt wechseln
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
Xbox 360 S wont stay on
How can I fix my Xbox 360 (slim)? It keeps turning off. It cuts off 8 to 10 times before it comes on for good. The eject button doesn't work and I have to turn on the console from the controller. What can I do?
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
This question was migrated from http://meta.ifixit.com/Answers.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Have you tried a different power supply? The one you have might be bad.
War diese Antwort hilfreich?
Bewertung 1
All those things, the start button, the eject function, and the on/off symptom involve the same part (the faceplate). To me, it sounds like you have a faulty or loosely connected faceplate ribbon. If it still doesn't work correctly after completely disconnecting the faceplate and its ribbon from the motherboard, try replacing the faceplate. It's easier to replace the entire faceplate than to replace only the ribbon. May God bless you and your family today!
Xtreme Games Dallas
Bewertung 1
1 Kommentar:
I forgot to mention that the RF Module (the little green board your faceplate is connected to) can also be defective and easily replaced.
von
Antwort hinzufügen
Bernest wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 22
Insgesamt: 3,228
