Lots of answers, see if you can further diagnose. Feel the common wall and see if it is hot, also feel the outside walls of the freezer and let us know your results.
Condenser Coils are Dirty
If the refrigerator is not cold enough the condenser coils may be dirty. The condenser is like a radiator and must stay clean in order to dissipate the heat which was removed from the inside of the refrigerator. As the coils get dirtier the refrigerator becomes less efficient, which makes it work harder to cool down. If the coils are dirty enough, the unit will never be cold enough and will not be able to cool the inside of the refrigerator to the proper temperature.
Evaporator Fan Motor
If the refrigerator is not cold enough, the evaporator fan motor might have failed. Every refrigerator has a set of coils called an evaporator. The refrigerator may have one or more evaporator fan motor(s) depending on the model and evaporator locations. The evaporator fan motor circulates the cold air from the coils thru the compartment. If there is only one evaporator it is in the freezer side. If the fan is not working, no cold air will get to the refrigerator compartment. The freezer may still get cold.
Condenser Fan Motor
If the refrigerator is not cold enough there might be something caught in the condenser fan motor blade, or the condenser fan motor might be defective. The condenser fan motor draws air over the condenser coils to cool them. The condenser fan motor is located underneath the refrigerator near the back. Pull the refrigerator out from the wall and remove the access panel to access it.
Start Relay
If the refrigerator is not cold enough, the start relay may be defective. The start relay is a small device mounted to the side of the compressor. It provides power to the run winding along with the start winding for a split second at start-up to help get the compressor started. If the start relay is defective the compressor may run intermittently or not at all and the refrigerator will not get cold enough. The start relay should be replaced if defective.
Temperature Control Thermostat
If the refrigerator does not get cold enough the temperature control thermostat might be defective. The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
Start Capacitor
If the refrigerator isn't cold enough the compressor might be having difficulty starting. The start capacitor serves as a battery to give the compressor a little boost during start-up. If the start capacitor is burned out the compressor might not be able to start and run as often as it should. Test the start capacitor first with a capacitance meter, they don't fail often. If it's defective, replace it.
Thermistor
If the refrigerator is not cold enough the thermistor might be defective. The thermistor is a sensor which monitors the air temperature. It is connected to the control board. If the thermistor is defective the refrigerator does not cool or may cool continuously.
Temperature Control Board
If the refrigerator is not cold enough the temperature control board might be defective. The temperature control board provides the voltage to the fan motors and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Compressor
If the refrigerator is not cold enough, the compressor might be defective. The compressor is a motor which compresses the refrigerant and circulates the refrigerant through the evaporator and condenser coils. There are several other components which are more likely to be defective if the compressor doesn't work. If the compressor itself is defective a licensed professional will need to replace it.
Main Control Board
If the refrigerator is not cold enough the main control board might be defective. This is not common. Check the defrost system, cooling fans, and cooling controls first.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
14
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
35 Kommentare
my ge profile fridge will cool for about a week and then the temp starts going up where everything in the freezer is thawed out and there is a defrost thing on it but after defrosting it it works good for about a week then the temp goes up again. what would make this happen?
von lilymarie485
Hi @lilymarie485,
Post your comment as a new question. That way it will get more attention.
Give information such as model number and some more information.
Such as is it only the fridge section that warms up, or the freezer section as well (bit confused when you say everything in the freezer is thawed out but after defrosting it?).
Can you hear the evaporator fan running when the freezer has been defrosted? (inside the freezer section of the fridge - all doors need to be shut, Not the compressor fan on the outside of the fridge)
von jayeff
Mine is making a whirring noise
von Janet Slinkard
My freezer is running no problem. My refrigerator compartment is running cool but not cold. I don't hear a fan running when I open the freezer compartment. I tried resetting. Still nothing resolved. What's going on? My fridge was purchased December 2016.
von JUDY PRINCE
I have had problems with my profile at about the two year mark and now at the 7 year mark it $@$* the bed completely. had the g e repair guys come numerous times and they all said the exact same thing, don't buy this p.o.s. the company doesn't care and the quality is horendous. so now after 7 years I have to lay out 2200 more dollars so my family can have fresh food. of course I cant afford it but g e wont give a &&^&. they don't make stuff like they used to and never will. I have lost all faith in any large company.
von detbotta
30 weitere Kommentare anzeigen
