iPhone Screen Replacement Doesn't Fit
What could be the problem if my iPhone 5 screen replacement doesn't fit?
I notice that the glass is separated from the actual frame of the screen replacement but even still if that was glued or fastened properly, shouldn't it still remain flat? I think the fact that it still sits awkwardly outward like that might reveal a deeper issue. Thoughts? Thank you.
See Photo
Ist dies eine gute Frage?
2 Kommentare
Yes but my point is the fact that it is still being pushed up may underlie another issue because this phone was repaired and had a shattered screen. I am wondering if the fall may have bent anything else inside the phone to make the screen pop out like that? You can also see that the frame that holds the glass is not flush...
von Taylor
If you are having an issue with the screen not fitting at the bottom (next to the home screen), some manufacturers put a sticker in this area. A few of the manufacturers i've had screens from have had a sticker covering a small dent in the screen which a part component of the main phone falls into when the screen is on. If this sticker is covering the hole the comment can't slot into it and therefor the bottom of the screen doest sit flush. Remove the sticker and the issue should be resolved.
von islandstores
