Zum Hauptinhalt wechseln
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
318 Fragen Alle anzeigen
Dryer won't start Error Code F70
Just had a Thunderstorm and lightning hit very close to our house blew 2 circuit breakers. I reset them and everything came on in the affected rooms. When my wife tried to start the dryer it wouldn't start and has an error code of F70 flashing. What does this mean and wan I fix it or do I need a technician?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 6
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Doug, F70 means check harness connections at the machine control and at the console electronics. If your connections are fine to the machine control board and the console electronics, then you may need to change the machine control board. Unplug your dryer first and leave it unplugged for a while to see if it resets It is below the top panel on the left hand side of the dryer panel. I attached the tech sheet for the dryer to the bottom of this page. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 6
3 Kommentare:
I replaced a circuit board run as described "https://www.youtube.com/watch?v=eWqrn5kl...: However, I did not properly seat one of the plugs. I reopened dryerthe board and checked the plugs. Once I found the loose plug, I re-seated it properly and the dryer came up perfectly.
Thank you so much for this excellent video.
von
Thanks to this information above I was able to get mine going too!!!! (Thank you)
von
coding F01 is iqual a F70?
von
Antwort hinzufügen
Doug wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 66
Insgesamt: 34,776
