Zum Hauptinhalt wechseln
Zweite Generation des CDMA iPad mit 16, 32 oder 64 GB Speicherkapazität und Dual Core A5 Prozessor. Modell Nummer A1397. Reparatur verlangt Feingefühl, Hitzezufuhr und Hebeln.
52 Fragen Alle anzeigen
Frage geschlossen
Would wwan board affect anything else other than internet?
While replacing the WiFi connector on my iPad 2 CDMA, since everything else used tape, I thought wwan board was attached by tape and I tried removing it so I could lift logic board. In doing research, I have found that I permanently broke and cannot replace this without buying a brand new logic board. Do I need wwan board for anything else? Power button not working and wondering if related or just a coincidence. Thank you.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You might not want to upgrade or reinstall iOS after that. The WWAN board is required for upgrading/activating your iPad. Without your original set of two boards, the iPad will be bricked if you try to upgrade/reinstall. There is no way out of this.
War diese Antwort hilfreich?
Bewertung 2
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 131
