Zum Hauptinhalt wechseln
Reparaturanleitungen für Handys und Smartphones des chinesischen Herstellers Huawei.
1875 Fragen Alle anzeigen
My Huawei Ascend Mate MT1 U06 wont't turn On or charge :(
It is like 5% left on my battery and i charge it with a (samsung galaxy y) charger and after an hour its dead. :( what's the problem of my phone maybe its the battery :(( Please kindly help me thank you .
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
4 Antworten
is it possible you don't charge it enough? Because it may show 100% battery but in fact be 15%?
Because its a common system error in android.
Of course it also could be that the batter need to be replaced, how long have you had your phone for? Has the battery looks the same size to you because sometimes it expands for some reason and just doesn't charge
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
I have my phone for about 8 months now, the battery seems okay but i think that the charger drain all the energy from my battery and that's why it won't turn on or charge., Is it possible?
von
Its not possible for the charger to drain energy from your phone the mains won't allow the charge to reverse its direction of electrons flowing through, the charger might however short circuit - its where the charge has chosen the shortest, least resistant path, and therefore the phone won't charge and the charger is broken.
However the issue of battery being drained when charging may only be possible when charging via USB port not and the a/c adapter.
I have two options what might have happened, either your charger is faulty or its a loose connector in the phone itself.
Have you checked the warranty? It maybe worthwhile to check whether it covers the issue you are dealing with.
von
Okay, Your response is such an honor to me aleks, thank you. I'll try to check it to the store where i bought this phone.
von
Hi there,
MY Ascent Mate 7 is off( like for good and all), i am trying to charge it but no sign that it's charging.
No signs of life :(
Any help, fellas ?
Bewertung 0
Hi,
I have bought a Huawei ascend mate, it would not charge or turn on, have replaced charging port and battery. Still will turn on or charge.
klem
Bewertung 0
My huawei mt1-u06 signal network down for six weeks How do i fix the problem.
Bewertung 0
Antwort hinzufügen
Kim Brylle wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 3,618
