Zum Hauptinhalt wechseln
Released May 1, 2012. The first backlit eReader tablet emits a soft backlight for improved night reading. The device is simple to open up, but the components are all connected.
33 Fragen Alle anzeigen
Nook Glowlight not working
Hi. I dropped my Nook with Glowlight and the case came loose. I followed the tear down instructions and took the Nook apart and put it back together sealing the case. It works fine except I lost the Glowlight feature in the process. I can't turn the Glowlight on at all. Any ideas or suggestions? Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I fixed it. There is a tiny ribbon cable in the upper left corner of the motherboard that I dislodged when I put the case back together. Plugged in the cable, closed the case and all is glowing as it should.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
MarkT wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 584
