Zum Hauptinhalt wechseln
Die zweite iPad-Generation mit WiFi, GSM und CDMA Modellen. Einige Modelle wurden noch einmal aufgepimpt vor dem iPad 3. Die Reparatur ist schwierig und verlangt Hitzezufuhr und Hebeln.
730 Fragen Alle anzeigen
Dropped my Ipad and now my touchscreen isn't working right
I recently dropped my iPad 2, and at first it was fine. Then, I noticed the touchscreen kept freaking out as if I were scrolling it left to right continuously. Eventually, it started clicking on things by itself and now I am unable to even click from the middle of the iPad all the way to the left. The panel is cracked pretty bad at the top of the device, could that be why my touchscreen is malfunctioning? Or is it something else?
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Sounds like you need a new digitiser. That sould solve your problem. Plenty of tutorials for it if you want to tackel it yourself, just take your time. :)
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
Thank you for your help! I looked it up and it sounds like that's the problem to me too.
von
Chances are there is also a dent in the case of the iPad. The odd behavior you are describing is ghost touches on the screen. Unfortunately its nothing cool like a poltergeist has possessed your tablet and you will now be able to move objects with it. It just means that something is pressing up on the screen, causing the digitizer to misbehave.
Luckily its a very simple repair. I highly recommend taking it to a reputable local repair shop to have the repair done. It will take them no time and your iPad will be as good as new.
Bewertung 1
1 Kommentar:
well ghost touches are impossible as the ipad is supported with heat as touches well y know what i mean
von
You know this is illegal to carry a cracked ipad, because apple doesnt want to look bad.
Bewertung 0
1 Kommentar:
how does it make apple look bad? its the buyers fault
von
Antwort hinzufügen
Kelsey wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 1,982
