Zum Hauptinhalt wechseln
7,9 Zoll Display / Modell A1432 / Verfügbar in schwarz und weiß / Angekündigt am 23. Oktober 2012 / 16, 32 oder 64 GB Speicherkapazität
220 Fragen Alle anzeigen
Easy fix for lcd?
Im replacing a smashed screen, everything went ok, tested the lcd and worked after screen off. Then i removed lcd and digitiser and replaced with new digitiser and it booted up to apple logo then went blank. I then reseated battery and lcd connections and backlight not working now and tried soft reset but to no joy.
By not removing the battery first have i blown the backlight? I dont have a clue about soldering so really want to avoid this route. Any other options?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
What is going on here is that the iPad requires a functional digitizer in order to fully boot the display. When you see an Apple logo then nothing--that equals a digitizer problem.
In your case, Wes, this is because the digitizer fpc connector is mangled---you may not have a backlight problem at all. But you will need to get that connector replaced, possibly also a backlight fuse but maybe not. Then this mini will be fine.
jessa
War diese Antwort hilfreich?
Bewertung 2
By not removing battery it's possible to blow the backlight
Email Jessabethany@gmail.com she will sort you out
Bewertung 1
Several months ago I spent something like this with a mini ipad retina... I connect the new LCD and everything ok, connect the new touch and the LCD blinked a few times and did not return on the LCD. My mistake was to have turned on the ipad and do not disconnect the battery at the time of change of the parts...
Bewertung 0
Antwort hinzufügen
Wes wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 359
