Zum Hauptinhalt wechseln
Modell A1369, 1.6, 1.7, oder 1.8 GHz Prozessor, 64, 128 oder 256 GB Flash Speicher.
328 Fragen Alle anzeigen
Frage geschlossen
keyboard and mouse pad doesn't work
Hi
I have MacBook Air A1466 . ( 2012 ) keyboard and mouse pad doesn't work. On a keyboard
Just power on switch is working. What's prob on it ? I changed keyboard as well. But it's still
Same prob.
Thanks .
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Have you tried using an external keyboard & mouse, does that work?
You state you changed the keyboard how did you do that? Please explain.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
The keyboard is riveted into the case on these MacBook Airs, but it can be replaced. It may not be the best way to do it as the keyboard is no longer riveted into the case, but it works.
von
The keyboard connects to the logic board through the trackpad on these machines. So perhaps the problem is with the trackpad. I actually recently ran into this with a customer's machine...it was acting as if the shift key was stuck down, so I replaced the keyboard. That didn't solve the problem so I replaced the trackpad and that turned out to be the issue.
Bewertung 1
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 333
