Zum Hauptinhalt wechseln
The Canon Powershot A1000 IS features a lens with 4X optical zoom and a focal length of 6.2mm to 24.8mm and maximum f-stops of f/2.7 and f/5.6.
6 Fragen Alle anzeigen
I can't see any picture on my Display.
I can't see any search-picture on my display, the display itself may be o.k., because when I use the menu-button I See the menu on the display. When I start ! see the informations on the display. What can I do?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
newsforpeter, this can be caused by a bad CCD on your lens. Check the ribbon cables and make sure they are properly inserted. Also check for corrosion and debris damage. If all that looks ok you may need to consider either a new CCD or a complete lens.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
newsforpeter wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 279
