Zum Hauptinhalt wechseln
My HTC M8 won't auto rotate how can I fix this?
I dropped my device and now when I try to turn it into landscape, it won't rotate.
Ist dies eine gute Frage?
Bewertung 5
1 Kommentar
I am having the same issue and I haven't dropped my phone. My motion sensor stopped working on the lock screen as well.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Sounds like a calibration problem. You can re-calibrate the phone by going into settings. Then select "display and gestures" and choose "G-sensor Calibration". Make sure its on a flat surface, though, so it calibrates properly.
War diese Antwort hilfreich?
Bewertung 7
8 Kommentare:
@Jose Estrada Still didn't work for me...
von
@Jose Estrada Nevermind! Restarting my device and then re-calibrating did the job!
von
WOW Thanks that worked perfectly.
von
I have the same problem, when i used your method it helped. Though when i want to move from horizontal mode to vertical mode ot just wont work. Any suggestions?
von
Thanks alot it's working hooowww
von
3 weitere Kommentare anzeigen
Antwort hinzufügen
andrya jazmine wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 17,869
