My infinix zero touch screen not responding, and wont power off
my infinix zero x506 touch screen is not responding to touch after system update
Ist dies eine gute Frage?
I have infinix zero 3 set and I got problem of screen touch not working and on searching on internet in XCLUB I got the way to solve this problem . The solution is Press power + volume up button for about 10 sec so that it may power off your phone then it will reopen with touch working correctly .thx for reading
War diese Antwort hilfreich?
worked like magic!
Mine is not working, pls help
wow, that was magic
very magic , magnificent
Thank you! Worked like a charm!
I have infinix Note 3 set and I got problem of screen touch not working for a day and on searching on internet in XCLUB I got the way to solve this problem . The solution is Press power + volume up button for about 8-10 seconds so that it may power off your phone then it will reopen with touch working correctly .
Mine isn't still working
After firmware update some phones required to reset. so try to hard reset device and check whether touchpad start to work.
I have tried to hard reset it still doesn't respond
I have infinix zero 4 set and I got problem of screen touch not working and on searching on internet in IFIXIT I got the way to solve this problem .
THANKS for reading
i have infinix zero 5. my mobile touch is not responding. how can i fix this problem.
( The solution is Press power + volume up button for about 8-10 seconds so that it may power off your phone then it will reopen with touch working correctly) i have used the above step also still my phone is not responding
My infinix hot 4 pro power button isn't responding anymore, can't power off
Infinix phone is not passbook
work whote problem
Infinix phone is not unionbank m passbook
work whote problem
Infinix phone is not union bank m passbook
work whote problem
Àll the lower digits aren't working i.e *0# and done on my infiix zero 4. What do I need to do ?
Hello hi sir plz
Sir I am used me infinix hot 4mobil my problem help me disply not Working on and of sensor auto matic
I have Infinix note 30 but i can't power of or restart my phone in touch but phone touch is correctly working but power of or restart not working any solution??
Sir plz help me my mobile is this problem is the Sher me model numbar hot 4 x 557 plz solved my cellphone is on display not the of Every time on screen display on
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 58
Insgesamt: 24,105
9 Kommentare
my infinix zero x506 the home menu not working even i reset the unit?
von tommy cabrera
my infinix note3 start navigation icons on the screen not working
please help
von josephken12
my infinix note 3 pro touch screen does not work properly at the lower part what is the cause of this and is there solution
von william
My infinix zero 4 has navigating icons and the screen is no longer clear what might be the problem
von Henry Khato
my infinix hot 6x screen is not functioning so how will I fix it and make it work again. if any notification comes I can't read the touch screen is not working so I need help please, someone should help me fix this problem.
von Aboagye Collins
4 weitere Kommentare anzeigen
