Why is my device not turning on?
I have tried charging my phone, I hold the power button for several seconds... it is just not turning on.
Ist dies eine gute Frage?
Hold volumn down, home and power button together
it should display a service screen from here you can factory reset it
also does it charge??
War diese Antwort hilfreich?
Try replacing your battery, this may be due to a drained battery. It happens when your phone battery goes through a lot of charge cycles. Replace your battery (which is placed under the rear case) and trying turning it on again.
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 140
I was listening to some music while I was taking a shower and whenever the phone got wet I just wiped the water and continue (this happens everyday) but yesterday there was something wrong for example my battery was 1% so I charged the phone and in 5 mins it reached 42% but of course it did not last long . and later on the phone kept showing that its charging but the charger was not plugged in .at night I plugged in the charger and slept and now the phone is not turning on . what should I do ?
von rakan attyeh
its probably liquid damaged
von daniel
