Zum Hauptinhalt wechseln
Ursprünglich im Jahr 2001 veröffentlicht, identifizierbar durch die Modellnummer VT750DC.
The lights are not turning on but the engine is running.
When I start the motorbike, the engine starts up just fine, but the head lights do not turn on no matter what I do. How can I fix this?
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Lights are not working
von Teilen
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
If the head lights are not turning on even though the motor is running, the bulbs may be burned out. Make sure they are screwed in all the way and check the connection wires to the lights. If this does not solve the problem, they will most likely need to be replaced. Please refer to the troubleshooting guide for more information.
War diese Antwort hilfreich?
Bewertung 1
Check bulb and fuses. Then check if power is getting to the bulb with a volt meter.
Mine has new bulbs and fuses along with power to the bulb, but still isn't coming on.
Bewertung 0
Antwort hinzufügen
Daz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 40
Insgesamt: 601
