It's been a long time, but should someone read this:
The components are:
1/ Capacitors linked to ground: by jumping them, you create a short to ground. This MUST be avoided at all cost. remove the jumpers and look for other culprits. The 3 small caps can be discarded. It is better to replace the bigger one, but if this is not possible, better leave it without anything.
2/ Those capacitors have nothing to do with the back camera, they are related directly or indirectly with the compass. Worse case scenario: leave them missing and your compass may act out, but otherwise the iPhone should behave normally.
3/ The iPhone board has an identification number. Find it on the board. Use it to pull the schematics, look for the circuit of the back camera. This can help solve it. Running around jumping components (specially capacitors which mostly are connected to ground) will only cause shorts to ground, overheating, further damage to the board.
4/ If you need help solving such an issue, post a separate question for your device, and an "excellent" quality picture of the board where the components are missing/damaged. This way you can get help identifying components, their function, and possibly finding a solution. If you can't post a good quality picture, do like qchung did here: post a good quality stock picture of the board, but mark the ones that are missing in your particular case.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
3
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
3 Kommentare
any little help here please?
von qchung
I have the same problem with my iPhone 5. Tested 2 working cameras on same motherboard and both of them failed to work.
von ivantrlin97
Hi ivantrlin97, check my answer below.
von Rany
