Zum Hauptinhalt wechseln
The Trek 4300 is mountain bike released by Trek in 2003.
What is the psi recommended for pumping up the tires?
I know road bikes need like 100psi, but since this is a mountain bike what should I pump them up to?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
The recommended psi for the tires on this bike is 40-65 psi. This can be accomplished using a standard manual bike pump or a compressor with a bike attachment. It is important to check the psi of your tires after inflating them.
War diese Antwort hilfreich?
Bewertung 4
Look on the sidewall of the tire.
Generally mountain bike tires have a lower pressure than a road bike, but it is important to read the specifications stamped on the tire. Also, if you are riding on the road primarily, you might want a higher pressure to fight rolling resistance.
If you are riding loose dirt, mud and that sort of thing, you might want a slightly lower pressure than what is listing as MAX on the tire. This will give you a better handling bike.
If you are riding a mountain bike on pavement, use slicks or semi-slick tires. These usually have a higher pressure. The specifications depend on the type of tire, and terrain.
Bewertung 2
The Standard For City/Not specifical User ist 4 bar,means (59) 60 PSI.
For Offroad use ist round 30 PSI.
BUT EVER SEE BEFORE WHAT IS ON PNEUMATIC SEITE,because Here ist exactly specifical Presstüre dir Tour Tyre.
Bewertung 0
Antwort hinzufügen
Jimmy Todd wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 41
Insgesamt: 4,254
