Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
10 Tassen Kaffeebereiter. 900 W, Typ KF 440. Made in Germany.
3 Fragen Alle anzeigen
Why do coffee grounds keep showing up in my brewed coffee?
Almost every morning, i get a nice mouthful of coffee grounds when i get towards the bottom of the pot. What is the easiest way to eliminate this issue without buying a new coffee maker?
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
A lot of times, this is caused by the paper filter not sitting in the coffee maker correctly.The easiest way to fix this is to buy a reusable filter. The reusable ones don't ever have issues like this. If you don't want to do this, I was always told to flip the paper filter inside out before installing in which helps it stick to the walls of the basket.
Here is a link to the Bruan Aromaster KF440 Trubleshooting page which may answer more of your questions: Braun Aromaster KF 440 Troubleshooting
War diese Antwort hilfreich?
Bewertung 2
Kommentare:
I fold mine on the two sides so the seam is flush with the cone wall. When you fill the cone make sure it is smooth against the wall of the holder. Lastly, don't wait to long placing the carafe underneath as the water level can rise above the filter cone with the grounds leaking over to the clean side of the filter which then enters into the brewed coffee.
von
Antwort hinzufügen
Dennis wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 9
Letzten 7 Tage: 101
Letzten 30 Tage: 440
Insgesamt: 5,848
