New battery recognized but will not run on battery
Early 2011 MBP battery not charging, indicated 0% charge and "Replace Now". Computer is from an office environment and has NEVER suffered any liquid spills, drops or other damage, it is in like new condition. Purchased and installed new A1382 battery but will not run without AC adapter connected.
Computer runs normal on A/C power but is not charging battery. LED on MagSafe stays bright green. Tried another 85W MagSafe adapter from wife's MBP, same problem. Bought a new Apple 85W adapter to be absolutely sure, same problem. System runs fine on A/C power but LED will not change color and battery not charging. With A/C adapter connected, I reset SMC and NVRAM but no change. LED on MagSafe did not change color either.
Battery meter on side of computer does not work unless A/C adapter is connected, then all but last LED will light up. Ordered and installed MagSafe Board from iFixit, no change, reset SMC and NVRAM again, no change in battery status. Booted AHT (Apple Hardware Test) will not get past the following error "4xxx/4/40000005: Battery"
Returned and received another A1382 battery, re-did all of the above, same problem.
Suggestions?
Ist dies eine gute Frage?
I have the same problem! Did you find a solution to fix it ?
von Leonardo Corona
@leocorona - Sadly this one slipped through the cracks. How about creating a fresh question with all of your details so we can see if we can help you.
von Dan
