power button doesn't seem to work
Hi everyone,
my Oneplus One power button doesn't seem to work anymore so I can't turn it off or reset or anything. I keep it charged and use it anyway. I removed the back cover and tried pushing the real button under the plastic one but it doesn't work either.. (the volume one works fine this way) Is there a way to repair it without voiding warranty? I'm also waiting for the assistence to respond to my ticket.
Thanks!
Ist dies eine gute Frage?
3 Kommentare
I have this also - anyone had any experience with this? I have many workarounds for daily use but it'd be great to have a go at fixing this.
I've taken the back off the one before but never done any unscrewing to get at the real internals. If someone's had success doing this and some pointers I'd maybe have the confidence to dig a little deeper but this is about as far as I'm comfortable to go at the moment.
I've seen videos of opening up the one but not one that goes into any detail on the power button
von Ciaran Fitzpatrick
Without the back cover some contacts are not closed and it is impossible to start the phone.
I have the same problem after fixing my problem with the not working display because a latch was slacked off. On opening the cover of the cpu part I did damaged a small latch only 2-3 mm above the power button. Maybe you damaged this small latch on the side while opening the back cover?
von Wolf Linden
Remove you round window protective cover . to stop the automatic cover close up . this would surely amend power button and make it work again .
von fareedharb
