Zum Hauptinhalt wechseln
Sony Xperia TL / Model: LT30AT / Dual-core 1.5Ghz Krait / Black, White, Silver
The screen is frozen and it won't turn off or on
The screen locked and nothing is functioning. Turning the phone off does not help. The only thing that seems to work is letting the battery drain to force restart the phone. Is there an easier way around this?
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Try doing a power cycle. To do this hold the Volume Down button and then the Power key simultaneously for about 15-20 seconds. If this does not work, try holding the Volume Up button instead of the Volume Down button.
Make sure to do this while the phone is not plugged into a power source. It also might take a few tries.
If this continuously fails, the battery should be replaced. There is a guide on this page for that.
War diese Antwort hilfreich?
Bewertung 16
8 Kommentare:
Excellent advice worked first time. Thank you saved me sending it away.
von
Oh I love you
von
what causes this to happen?
von
ankitis beat me to it...…………………..I love you also :-) Worked first time with the volume up advice x
von
Thank you - worked first time for me too :))
von
3 weitere Kommentare anzeigen
Bewertung 0
thanks. it worked with mine
Bewertung 0
Antwort hinzufügen
Nathan Laneau wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 15
Insgesamt: 16,136
