Why does my phone have no audio?
I left my phone at the bottom of my bag where it took up dust. How there is no audio, with or without the headphones plugged in.
Ist dies eine gute Frage?
i had the issue and i got it fixed i hope this will help others too . just restart the phone and see if any application is blocking the sound . see the sound settings and check if there is any phone software is available for more steps Guide~Fix Sound In Phone witbout Reset see if this take care of your problem
War diese Antwort hilfreich?
I solved the problem. If the audio and sound are not working with your phone, there are a few possibilities that may be causing this. The easiest solution to this would be turning the volume up using the volume buttons on the upper left side of the phone. If the phone was muted then that would explain why the audio and sound were not playing. If this does not work and the volume was already turned up, you should reboot your phone. If neither of these fix the audio problem with your phone, then the speaker is most likely broken and you should refer to the link on how to replace your speaker.
I have to do the restart several time a day
Rebooting the phone is the best answer. First, you can check your ringtone if the speaker is working. After rebooting your phone, still nothing happens, the speaker might be malfunctioning.
Letzte 24 Stunden: 5
Letzte 7 Tage: 15
Letzte 30 Tage: 59
Insgesamt: 47,976
7 Kommentare
I'm going to turn off my phone now so if I lose you and can't get back to this place, thank you
von Cody Grant
Nothing is working I can't get my phone sound for anything I have tried everything I can't talk to anyone due to this
von Julie Anderson
Audio of my phone is dis connected
von Lerma Bensan
No. Sounds on my phone what to do
von Stephanie Jones
My phone rings but I cannot hear anyone and they cannot hear me. When I call someone I don’t hear the phone ringing but the person I’m calling sees the incoming call but no sound.
von Jean Houston
2 weitere Kommentare anzeigen
