Zum Hauptinhalt wechseln
The Wii U is a video game console paired with a handheld device made by Nintendo that allows users to play games on the GamePad. Repairing the console is straightforward as the device is very modular.
Replacement ribbon cable clamp?
So today I decided to replace my gamepad screen, since my old one had a scratch that make a area of the screen untouchable. Seems while in the process one of the ribbon clamps came off.
here it is.
I found it, but while trying to put it back on it snapped in half. it looks like this one.
Here.
Anyone know if (and where) I can find a replacement, or a way to make it work? Everything works fine except for touch, which is what this cable is for. I hear electrical tape can work, but I don't know what exactly to do with that.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
Position the ribbon cable onto the conector and then use white tak...its like blue tak but kind of sets harder!...to keep the cable pressed down.
This worked for my one!
You might have to try a couple of times before you get it to work!
Take a look at my YouTube video...
https://m.youtube.com/watch?v=mNbxeLlpaO...
http://www.amazon.co.uk/WHITE-TACK-BLUE-...
War diese Antwort hilfreich?
Bewertung 1
5 Kommentare:
Would love to see this youtube video. I just tried and got nothing :/ Is the ribbon supposed to lay on top of the connector, or under? It slips in under so i figured thats the right way to do it.
von
Just doing my vid today... i'll post on YouTube tomorrow and I posted the link asap.
von
Awesome, thanks!
von
great solution, thanks!
von
Hilfreichste Antwort
The ribbon cable socket is desoldered from the logic board. It can be soldered in place but this have to be done by a pro. Find a place that repair iPhones and ask them to do the job.
Bewertung 2
8 Kommentare:
Isn't the socket what the ribbon cable goes into? I'm just talking about the gray thing that clamps down on it, unless that's what you're talking about.
von
OK, doublechecking at the first pict I think that it's the cable that need to be replaced. The connector is desoldered from the cable and seat now in the socket. Not sure that the connector can be soldered to the cable.
von
Looks more like the grey clasp is broken off. It provides downward pressure on the cable and allows it to make contact.
von
oldturkey, is it the same type of socket than the keyboard backlight socket on a MBP ? You insert the cable in it and push down a lever to secure the cable ?
von
The cable's fine, the angle just makes it look weird. I am talking about the gray part that clamps down for pressure.
von
3 weitere Kommentare anzeigen
I need this answer too. Chrisall76 did you ever get something to work?
Bewertung 0
1 Kommentar:
Nope, had to buy a new gamepad.
von
Does electrical tape work?
Bewertung 0
1 Kommentar:
i taped it with gorilla tape... but when i had to replace the touch screen the tape didnt work anymore.... im trying hot glue next
von
i did the same to the clasp that is for video....the one in your second pic. i put tape on it....keeps going off. i started to put hard things on top of the ribbon with tape for pressure and still comes off. some said glue but i dont like that idea because one it can cover the pins and two what if you need to replace stuff and it cant come out. i was wondering if the clasp was replaceable too
Bewertung 0
1 Kommentar:
Fixed this whith white tak...
von
Antwort hinzufügen
chrisall76 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 33
Letzte 30 Tage: 54
Insgesamt: 12,020
