Zum Hauptinhalt wechseln
2,26 oder 2,4 GHz/ weißes Unibody-Gehäuse aus Kunststoff
645 Fragen Alle anzeigen
Rescuing files from dead laptop's hard drive
My old MacBook Unibody Model A1342 late 2009 laptop won't start. The cause for this is probably a water damage.
Nothing major, just few drops of water in wrong place and that's that, so I'm sure that the hard drive itself isn't damaged. I'm not going to repair the laptop, but it would be nice to have the files from the hard drive.
What are my chances to rescue the files?
I viewed the guide for replacing a hard drive from this site and I'm capable to remove it, but what I should do next to rescue the files?
For example, am I able to connect the hard drive to PC?
I also have MacBook Air, so is it possible to connect the old internal hard drive as an external to it via usb?
Thanks in advance for any help.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
of course tony, just buy a SATA/USB adaptor or case like this:
http://www.ebay.co.uk/itm/Slim-2-5-SATA-...
i brought cheapest usb3 case time ago, when i plug, it make an interference that stop network.
maybe find better one.
good luck!
War diese Antwort hilfreich?
Bewertung 5
1 Kommentar:
Thank you for your response! I will look for those that you mentioned. Even though I deal a lot with computers, I'm kind of inept with computer hardware, so I didn't knew how this kind of procedures are done.
von
Antwort hinzufügen
Tony wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 156
