Zum Hauptinhalt wechseln
Repair and disassembly guides for Kenmore Microwaves.
182 Fragen Alle anzeigen
How to access vent light button assembly to reattach button assembly?
I have a kenmore elite microwave hood combination model 790.8037. Vent and light button assembly detached from front of microwave. The button assembly fell behind the face of the appliance. How can I take face of microwave off so I can reattach to face?
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar:
I have same problem. My microwave model 790.80362310
von
Einen Kommentar hinzufügen
3 Antworten
Were you ever able to fix this? Our vent light button assembly just fell in. I haven't had luck finding directions for taking apart the front face or buying replacement parts. As best I can tell, Sears recommends buying and replacing the entire control panel assembly (Part #: 5304491493 $263, plus labor).
http://www.searspartsdirect.com/model-nu...
War diese Antwort hilfreich?
Bewertung 0
Just unscrew the bottom of the hood and take it off. You can the reach behind where the buttons are and tape them back on or glue them.
Bewertung 0
4 Kommentare:
I removed bottom of the hood but still can't access the vent and light button to reattach.
von
You should be able to see the buttons inside. You will have to glue them back with super glue.
von
I did end up fixing it with super glue. Had to slide the whole panel up and pop it out so I could get underneath and re-attach the button assembly.
von
Hello could you describe what you mean by slide the panle up
I am working on it now
von
Thank you for this useful post.
From the image of the panel on Sear’s parts page (OP’s link) you can see the location of the one screw that holds the panel in place. The panel has tabs that slide in then down. To get to that screw remove the vent/filter trim piece on the top. The one screw keeps it from being bumped up and off. Beware of the wires. There’s not much room to work. I took the bottom trim off but maybe that wasn’t necessary. I’m trying super-glue in three points. Looks like original installation was glue on the heads of three screws then pressed into place. If my effort at super-glue fails I’ll try using a small block of wood behind the switch plate to wedge it in.
Bewertung 0
6 Kommentare:
This just happened to our microwave yesterday. Thanks for this info. Will try this fix today.
von
Judie Silver, were you able to fix it? I'm confused if I take off the panel on the bottom or the panel on top. It's very awkward to work over the stove.
von
I fixed my Kenmore convection oven/microwave #80373. Through the "top" method, Do not remove the bottom trim. Super glued the 3 points, and a touch of duct tape on edges of circuit board to secure it in place against the plastic frame. Works beautifully! Thank you everyone!
von
Okay, I'm doing this now and here are the steps.
1. Unplug the microwave as you will be accessing electronic areas
2. Open the mircrowave door, remove the upper vent guard to reveal the 1 screw holding the control panel in place.
3. Remove the screw, grab control panel and slide it up and then pull out to reveal inside
4. Disconnect wiring if desired (take a picture) but remember what wire when where. Or, just work in the space provided leaving the wires attached.
5. Fix the buttons as needed (glue, wood, etc.)
6. Reattach the wiring if you detached anything, put the control panel on and slide down.
7. Reattach the holding screw and vent cover.
von
Glueing did not work. Were you successful using wood?
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
David Hadley wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 44
Insgesamt: 5,112
