Zum Hauptinhalt wechseln
15.6", Intel HD Graphics, Core i3 2330M, Windows 7 Home Premium 64-bit, 4 GB RAM, 500 GB HDD
58 Fragen Alle anzeigen
Frage geschlossen
lap wont start on and with continous beep.what's the problem?
When I turn on my laptop,there is nothing on the screen.just a continous beep sound.like..beep beep-beep beep-beep beep.....
As the switch is on,the fan rotates and then suddenly it stops.just the beepsound alone.what might be possibly have gone wrong?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
If you have already researched the issue on google (search model and issue) and have not found any decent suggestions, I can pose possible problems for your perusal:
-Ram could be bad
-Temperature sensor could have gone out or reading improperly
-Hardware hardware hardware: did you install something recently? =
-Short: I've had an issue one time where the power button itself was shorting out the board during boot up
Other than those standard causes, I would need more information. Do you see any image on the screen during boot? Any bios splash screen?
What were you doing before this issue occurred?
War diese Antwort hilfreich?
Bewertung 2
If RAM is not detecting by processor it make beeps for indicating that RAM is not in the computer. It happens usually when carbon creates between RAM and mother board slot. Simply open RAM and clean it properly with paper as well as slot and connect as it was before. Now turn on your computer it will start working.Thanks.
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 235
