Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
The Iconia A110 is an Android tablet released by Acer in October, 2012. It features a MicroSD slot, HDMI port, a 7" multi touchscreen display, and a 2.0-megapixel front camera.
15 Fragen Alle anzeigen
USB device not detected on pC
I've got 2 Acer Iconia tablets A110 and one is detected when I connecte it to PC but the other one is NOT detected. The conditions are identical but the results are NOT while connect them to PC. Might anybody help me with a solution? Thanks very much
Ist dies eine gute Frage?
Bewertung 0
Kommentare:
Are they running android OS?
von
Josh, Yes tablets run android OS
von
Einen Kommentar hinzufügen
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
2 Antworten
Hilfreichste Antwort
Make sure USB debugging is turned on, it maybe a setting. You can find the USB debugging option in your settings. Depending on what Android OS your running, its either under applications or developer options.
Check the device that connects settings, then check the other device and make sure they match, that's a quick way to rule out a software glitch.
War diese Antwort hilfreich?
Bewertung 1
OK so we are clear here: You have to of the same Acer Iconia tablets using the same USB cable one is able to be seen by the PC and the other not. Both are working and both have the same OS revision.
Try this, with the one that is working leave it plugged in and then using a second USB cable connect it to the second tablet. Is it able to be seen then? If not I suspect the USB port on the tablet is bad.
Bewertung 0
Antwort hinzufügen
Jon wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 5
Insgesamt: 862
