First do a Master Reset. To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a “reset” signal to all the components. (This is a common fix that many appliance repair mechanics use – it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed.
Is the machine completely going through the spin cycle at the end of the wash?
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
My washer wasn't draining or spinning. I have a Kenmore 80. I discovered the lid switch was bad. Now it drains perfectly but won't spin on its own after the rinse cycle. I have to turn the dial back to spin and pull out. Then it works. What could be the cause?
von David Wade
