Is there a way to replace the camera on the display?
Whenever I open Photo Booth or Skype, my MacBook says no camera can be found. Is there a way to replace the camera or check if a cable came loose on the motherboard?
Ist dies eine gute Frage?
I've never seen the actual camera go bad. Most likely is a bad cable connection. Check step 6 of this tear down to make sure it's plugged in correctly. This is an easy fix. MacBook Pro (15 Zoll, Ende 2008 und Anfang 2009, Unibody) Display tauschen
War diese Antwort hilfreich?
Well since it's a unibody you have to remove the entire display assembly.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 493
