Zum Hauptinhalt wechseln
Benutze eine unserer Anleitungen für die Reparatur deiner Armbanduhr.
50 Fragen Alle anzeigen
New battery for SkyCaddie GPS Watch?
I am trying to change the battery on my Skycaddie GPS watch. Can anybody assist with the model / serial number of this battery? and where I can find it on the internet. The only other batteries I find are related to handheld GPS devices and not the Skycaddie watch.
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
I was able to replace my battery with battery found on ebay. 3.7V 300mAh Rechargeable Lipo Battery Pack PCM 602030 High Rate for MP3 MP4 . You must cut connect off old battery and solder on to new battery. Watch working great. My recommendation is you measure the physical dimensions of your watch battery to make sure same as this battery. Mine was, easy replacement.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Where did you purchase this battery?
von
I have a Skycaddie sport watch.
Battery has always been bad....I decided to change it out.
Battery:
1.11wh CE UL
new 452530 3.7v
300mah 131009
I am having no luck finding the replacement...I would appreciate any help given.
Thx,
Ross
Bewertung 0
1 Kommentar:
Did you ever find the battery for your Sky Caddie 360? I need one for mine if you could pass on the information. Battery:
1.11wh CE UL
new 452530 3.7v
300mah 131009 < our number (140625) all else was the same
Thanks Jerry
von
where did you get this battery from?
Bewertung 0
1 Kommentar:
it came with the watch
von
Antwort hinzufügen
Kincaid wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 2
Letzten 30 Tage: 5
Insgesamt: 1,660
