Zum Hauptinhalt wechseln
The Asus X200MA is a portable touchscreen laptop with an 11.6" display. This device was manufactured in 2014 and is also identified as Asus X200MA-RCLT07.
37 Fragen Alle anzeigen
Why won't my laptop charge properly?
I charge my laptop for hours and it shows that the battery is drained or isn't charging.
Ist dies eine gute Frage?
Bewertung 9
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Vanessa,
First, make sure the charger is completely plugged in. If it is, it may the outlet that isn't receiving power. You can test that by plugging something else into it.
If that still isn't working, you may have to replace the battery. The same thing happened to my computer. Replacing the battery fixed the issue.
I hope this helps!
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
I just replaced my battery. It worked well for nearly a month but now I'm having the same problem. It's plugged in but the battery is not accepting the charge.
von
I have the same problem. I just use my laptop 9 months. but now it's dont want charging (just keep 0%) and the battery indicator flashes. Do replace a new battery can be more durable ? Then how the technic of using the batteries so it's can be durable?
Bewertung 0
My ASUS R510C Notebook PC does not power up if I disconnect it from my household electrical receptacle. Do I need a new battery
Bewertung 0
Antwort hinzufügen
Vanessa Garcia wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 16
Insgesamt: 1,968
