Zum Hauptinhalt wechseln
Erste iPad Generation mit Wi-Fi, verfügbar mit 16, 32 oder 64 GB Speicherkapazität. Modell Nummer A1219. Reparaturen sind unkompliziert und verlangen keine Wärmezufuhr.
130 Fragen Alle anzeigen
Is it possible to build an Ipad out of parts from online?
Hey Guys,
I was wondering if it's possible to build an ipad out of parts ordered from online?
LIke i found a few sites where you can get the LCD and the case, but i'm wondering if it's possible to order other parts like the logic board and the speakers. etc.
Would it be possible?
- Ez
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
6 Antworten
Gewählte Lösung
Parted out an iPad will probably cost double what a brand new one does.
War diese Antwort hilfreich?
Bewertung 4
3 Kommentare:
That is unless you buy used parts. Also you'll have to pay shipping on every single part, not just one unit.
von
Buy one with a broken screen, then buy one with water damage.... Profit?
von
mayer is right!
The PCBs and the chips are expensive in small volume!
von
it is possible but it cost a lot that it might not worth it.
Bewertung 1
and the best bit is, apple would not repair it, if something goes wrong...
i was going to buy one with cracked screen. i first was told by apple care "just bring it in, and we will fix it for you". then i have dug a bit deeper and have asked another apple care professional, if it really is replaceable in apple stores, he said to me, i would be turned away... i am not going to do anymore business with apple anymore. this iPhone is also the last one...
the way they make things is simply not good enough for me. if glass can be shattered so easily, why the $&@$ no one makes it out of plastic? i know, i am barking at the wrong tree...
Bewertung 0
3 Kommentare:
If you don't like Apple engineering just wait till you open an Acer ;-)
von
Open an ipad it not built all that good just like all other stuff coming from asia
von
Open an acer???, open an HP!!!!! The HP had like 3 tons of duct tape in it.
Apple engineering is actually pretty elegant compared to most other stuff out there.
von
I bought %70 of the parts needed to build one myself. But the eprom chips have the preloaded software from Apple. And not to mention the flash hard drive. What I did do was order from A web site called Dealextream about %50 of the unit. We in Toronto Ontario Canada have a mall called Pacific mall. In it has about 200 small china like stores with the rest of the imports for the Ipad. You are almost assured that most stores only carry Ipad 1 parts in stock. Cost to date is about $300
Good luck
Bewertung 0
There are many iPads available on eBay that are bricked by what is called an "iCloud" lock and others which are cheap because they have shattered glass, etc. So Apple is checking serial numbers before it lets your machine work, or download apps, making building from scratch a non-starter. But swapping id from a physically broken machine into a locked chassis might be a doable project to get a cheap iPad.
Bewertung 0
How about taking the parts of a broken iPad screen with screen and attaching it to a larger touch screen for something like a diy touch table.
Bewertung 0
Antwort hinzufügen
Esmond Ruslim wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 24
Insgesamt: 22,600
