Errors in the range of 4000-4016 have to do with issues involving the USB connection or security software.
Check USB connections
If there’s an issue with the USB port, cable, dock, or hub, or if the device becomes disconnected during restore, try troubleshooting the USB connection, then troubleshooting your security software.
To narrow down the issue, you can also change up your hardware:
Use another USB cable.
Plug your cable into a different USB port on your computer.
Try a different dock connector (or no dock).
Add (or remove) a USB hub between your device and computer.
Connect your computer directly to your Internet source, with no routers, hubs, or switches.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
