Pls help! MBP Won't turn on, no chime, no noise.
I really your help here. I have MacBook Pro 15 mid 2009 A1286 unibody. I was using it and screen disappeared on me. I tried to turn back on but no noise, no chime or no lights on keyboards.
I tried put on charge and yes it's genuine 85w apple charger but nothing happened. I pulled the battery out and tried to fire up just with MagSafe. Nothing again.
Tried SMC reset.
Tried another new 85w MagSafe
Even put in new Anker battery.
All the connector on logic board are visible, I unplugged them and reconnected em already.
When I plugged the charge I get green light on the connector and it also turns orange like it supposed to do and after while it turned green. Means new battery was charged up. And the side bar shows all green lights but as soon as I unplug the MagSafe. It's shows no charger on the sidebar. And the battery that was charged up for hours show no life on the side bar check. MBP is not booting at all.
Also tried 10 second push down with and without the battery and MagSafe. But no luck.
Also tried Ram pulling out one by one and pushing power button for 10 seconds but no luck.
There is no apple store around here up in North of Alberta. I have to go 6 hour drive. Only thing I can do is order parts and replace one bye one.
Please help me out. All of you wonderful and knowledgeable people. I thank you in advance for your time.
Manny
Ist dies eine gute Frage?
4 Kommentare
Hey MrMann911---Are you up for grabbing your multimeter and doing some motherboard troubleshooting? I can take a stab at walking you through it if you want to give it a shot.
It sounds to me like what you're really asking is "Does my laptop failure fit any commonly known patterns of failure, hopefully with an easy DIY solution" and the answer to that is "no. and no."
But that doesn't mean it's not repairable. If you've got a working multimeter and some screwdrivers we can do some investigating together. I can point you to where the information is, but I can't serve it up on a platter. If you're game, let me know.
Step one: open that sucker up. You'll need to figure out what motherboard you have. Start unscrewing and disconnecting things. You'll find a number that is not on the DC in board, but on the motherboard itself. What is this number? 820-2532 or 820-2523?
von jessabethany
Thanks for replying. Sorry for replying late cos I work 12 hour shift for straight 11 days and off for 3. I will buy the multimeter and will open up logic board. I did look through some pages and I tried to power up without power button and I didn't have multimeter and didn't wanna short circuit. I have a picture but not an actual pic of my own Mother board. I will open up and follow up your suggestion or the links if you have for me.
Thank you so much for your effort Man.
http://www.insidemylaptop.com/turn-on-ma...
My MBP looks like 15" mid 2009 one.
And this one doest have 2 pads to power up and bit risky cos I could short other pins up.
von MrMann911
Sorry I just realized! Thank you miss!
von MrMann911
I had the same problem. Tried your link to find the power pads and it fired right up, was told it needed a logic board but just needs a keyboard. Thanks
von Daniel Risicato
