Zum Hauptinhalt wechseln
Vierte iPad Generation, erhältlich seit dem 2. November 2012 mit 16, 32 oder 64 GB Speicherkapazität. Modellnummerb A1458.
218 Fragen Alle anzeigen
Ipad 4 doesn't charge
Hello, I installed a new battery and a new lightning port. My iPad turn on, but the battery doesn't charge, when I plugged it to the power outlet, the iPad only indicates "battery charged" when It had only 65% of charge. Only It charges, when my iPad is turn off, but when It turn on, it didn't charge. Now, my iPad doesn't turn on. I changed the battery two times. Also, I re-installed the old lightning port.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It is very likely that you have damaged the U2 charging logic ic chip, probably happened because you created a short on the main board while trying to replace the battery. It is repairable but it requires a board level repair.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
do you happen to have a picture of the chip that needs to be replaced
von
Antwort hinzufügen
Michael Beltran wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 482
