Zum Hauptinhalt wechseln
Die dritte Generation der Samsung Galaxy Note Phablet Serie wurde am 25 September 2013 veröffentlicht. Es trägt die Modelnumer N9005.
247 Fragen Alle anzeigen
Note 3 imei certificate fail
I can not make calls or receive it says fails to register on network I upgrated also to version 5 . The phone was root before and also was having the same problem ( I try and manual to register it finds the local providers but it's fail to register , I try and few SIM card )
When I try the code *#0011#
The
Imei certi : fail
Ist dies eine gute Frage?
Bewertung 6
Einen Kommentar hinzufügen
4 Antworten
i am having the same issue if find how to fix it pls send me a way on my email and ty my email anas_mukresh_1996@hotmail.com
War diese Antwort hilfreich?
Bewertung 0
1. Please make sure the email account is correct when you registered samsung account.
2. Land on the email, check the junk mail, check whether the validation email be intercepted.
Bewertung 0
my phone imei null..phone is root
Bewertung 0
Buy a chimeratool 3 day license. Activate usb debugging under developer options(tap buld number about 7 times). root the phone and after that do imei repair with the original imei under the battery.
other alternative is to make a new falsh with odin. you can get the firmware from sammobile . this method will delete all your information so make sure you do a backup first.
Bewertung 0
Antwort hinzufügen
christis1975 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 5,730
