Which type of adhesive tape for front display?
I can´t see in the guide for replacing screen what type of adhesiv i should use for the new display to secure water proof?
Ist dies eine gute Frage?
The new screen should already have the adhesive applied to it. If not, then you will need 3M 300LSE Double Sided Adhesive. You can buy it by the roll which comes in different widths from 1mm up to 12mm here is a link to some http://www.ebay.com/itm/261807573229?_tr.... Or you can buy a sheet of it that comes in many sizes also, here is a 4"x8" sheet http://www.ebay.com/itm/3M-300LSE-Double.... You can also search for sheets that are specifically cut for your device.
War diese Antwort hilfreich?
You will need a special two sided stick tape for the front display. You can find it on line pretty much anywhere. Most everything I found was either 5mm wide or 2mm wide.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 2,566
