Zum Hauptinhalt wechseln
The Asus X200MA is a portable touchscreen laptop with an 11.6" display. This device was manufactured in 2014 and is also identified as Asus X200MA-RCLT07.
USB 3.0 replacement on the left side
OK i was using it in class and stuffed it in my bag to move classes and the flash drive took out the USB inter face on the laptop how can i replace the USB port on the left side of the laptop
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
If you, or someone you know is good at soldering, you can get the USB interface port online. If not, I would take it to a professional.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
thank you i think i might get it services also do you think that if i send it in to asus they can fix it or would it be cheaper to get it done local in baton rouge
von
I would get it done local, It's a pretty easy repair. If you send it to ASUS...You may be without a computer for a good while.
von
thank you im going to get it done local
von
Antwort hinzufügen
Cory Pixley wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 18
Insgesamt: 675
