Zum Hauptinhalt wechseln
iPad Air Wi-Fi und Mobilversion, Modellnummer A1475. Verfügbar in Space Gray oder Silber, Speicheroptionen 16/32/64/128 GB.
125 Fragen Alle anzeigen
I can't charge my iPad
When I connect the iPad to the power adapter it appears the green battery with the lightning mark but the i pad won't charge
I tried the restor
I tried another power adapter
I tried another cable
I tried hold the two buttons
But the issue wasn't solved
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
does the cable go in far enough inside the dock?
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Firstly,iPad Air Battery is particularly sensitive to temperature, There are a lot of friends would like to protect it with the Case. But when the weather is hot in the summer, may it will lead to dissipating heat is not good and it failure. So please take it out.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Sohaib Khelfi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 1,181
