Zum Hauptinhalt wechseln
4th Generation Apple AirPort Extreme Base Station (Model Number A1354)
wan port not detecting internet provider
my airport extreme suddenly stopped working. I can get internet through the ethernet cable direct from provider modem to my computer but not through extreme. I have tried reset and factory reset with no success. The LED indicator on the WAN port indicates it is working but no provider is being detected. If this is a hardware problem does anyone know of a possible repair.
Ist dies eine gute Frage?
Bewertung 6
2 Kommentare:
What does Apples AirPort Utility tell you?
von
Did you get things working?
von
Einen Kommentar hinzufügen
1 Antwort
Apple AirPort Extreme is a simple fix, it is either the antenna or the WiFi card.
if the WiFi light is on it most likely to be an antenna, you can get one off ebay for pretty cheap
here is the guide to fix replace it.
Apple AirPort Extreme Model A1354 Antenna Replacement
if you need to replace the WiFi card, here is the guide for that.
Apple AirPort Extreme Model A1354 WiFi Card Replacement
Apple AirPort Extreme Model A1354 Antenna Bild
Anleitung
Schwierigkeitsgrad:
Mittel
5 minutes
Apple AirPort Extreme Model A1354 WiFi Card Bild
Anleitung
Schwierigkeitsgrad:
Mittel
10 - 15 minutes
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
wmathie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 1,196
