Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
4049 Fragen Alle anzeigen
Does replacing the lower doc cause the touch scanner to stop working?
As subject says, replaced lower doc and scanner no longer works. Tried new doc same issue. Any suggestion? Do not have original doc to attempt.
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
No, replacing the charging dock cable does not prevent the Touch ID scanner from working properly, unless of course the charging dock is of such bad quality that it is actually causing this. But that would really be a first for me. Don't know if someone else encountered it...
However, tempering with the phone while replacing that charging dock may have caused something. For example, you could've damaged the home button flex cable or it's connector, or have some dirt on that connector. Take a hard look using good magnification (10x at least).
If you see nothing wrong, start with a simple thing: after connecting the home button, reboot (not restore) the phone, and try again.
If that doesn't help, the damage could be as I said to the flex cable it self. If it is damaged but not torn, it won't be visible to the eye. No way I know of to fix it, unless you can rewire that flex cable without damaging the components on there. Or it could be somewhere on that board. Look next to the battery connector and next to the screen connectors on the board. Do you see anything damaged/broken/missing?
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
krisfuqua wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 3
Insgesamt: 39
