I think you have a corrupted install and you need to repair your firmware.
So if I were you, I'd put the old battery back and restore the phone.
The easy way, try it first:
- Download and install the latest version of iTunes on your laptop (new version just out now);
- Turn off your iPhone;
- Press and hold Home Button;
- While pressing Home Button, connect your iPhone to your computer using a known good sync/charge cable;
- Your phone should turn ON and show you "connect to iTunes," while iTunes will tell you that it "detected an iPhone in restore mode;"
- You will be prompted to download and restore your firmware. Accept and leave your iPhone undisturbed until the process is over and your iPhone starts fresh.
NOTES:
- If you iPhone's Wi-Fi was not working properly before the initial update to 8.3 that caused this issue, then there is a high probability that the new restore will fail as well and your phone will remain stuck on restore. Let us know of that's the case; there could be a remedy;
- All your data will be erased, hope you have a back-up somewhere;
- You'll need your Apple ID and password to unlock your iPhone, if activation lock was ON (Find My iPhone ON) before the restore.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
