Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Erschienen im April 2014. CPU - Quad-core 2,3 GHz Krait 400, GPU - Adreno 330. Display - IPS LCD, 16M Farben, 1080 x 1920 Pixel, 5,2 Zoll. Interner Speicher - 16 GB, 3 GB RAM. Android OS, v4.4.2 (KitKat). D6502, D6503, D6543
60 Fragen Alle anzeigen
Xperia Z2 Wont turn on
I recently replaced the LCD screen and after putting it back together it doesn't turn on when the battery is connected. When i disconnect the battery cable the screen lights up and the battery icon shows up. When i plug it back in the LED light flashes three times and nothing happens.
Ist dies eine gute Frage?
Bewertung 10
Einen Kommentar hinzufügen
Nintendo Switch Kits
Eine schnelle Lösung, um wieder ins Spiel zu kommen
Switch Kits kaufen
Switch Kits kaufen
8 Antworten
Is this whilst plugged into a power source? Was the battery disconnected before the repair?
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
Yes...and yes
von
Same problem. Didn't leave the battery connected when I did the job, no. Any solutions?
Bewertung 0
Kommentare:
Same Issue for me too, would be interested if anyone has a solution.
von
Also having this problem. Was all working fine until I disconnected the battery to replace it. :/ Now it will look like it is charging with the red LED, but not actually turn on :/
Bewertung 0
anyone found solution for this?
Bewertung 0
replace the battery work 100%
Bewertung 0
Kommentare:
I just replace my battery as still not working..Dont waste your money
von
I have the same problem, i was thinking of a battery reseat
von
I just replace my battery too. Not working. Dont waste your money. Buy new one.
Bewertung 0
http://forum.xda-developers.com/xperia-z...
Bewertung 0
The flex cable connector is not fully seated. It worked out.
Bewertung 0
Antwort hinzufügen
Dylon Browne wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 13
Letzten 30 Tage: 48
Insgesamt: 6,605
