Zum Hauptinhalt wechseln
The product is an HS-10DTB2-8GB Android Tablet with a maximum height of 10.1", made for the convenience of using phone applications on a bigger screen display than a smartphone.
10 Fragen Alle anzeigen
Frage geschlossen
Why wont the rear case come loose?
I cant get the rear case to come apart using the plastic opening tools. How do I get this off?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Sometimes the rear case can be very tight. Make sure you have removed the two screws described in this guide.. Once you have those removed try using more than one plastic opening tool to pry the rear case off. If this is the first time taking your tablet apart it may be very tight from manufacturing.
War diese Antwort hilfreich?
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 84
