This may take some trial and error to find the problem. Resetting the SMC - First unplug the unit and press the start button for 5 seconds. Next try a PRAM reset, hit the start button and immediately hold down the Option & Command and P and R keys wait till you hear it tone three times. Next re-seat the RAM, here's how: iMac Intel 20" EMC 2133 und 2210 RAM austauschen
This failing you will need to open it and examine the diagnostic LEDs:
Here's a video on how to open it up:
http://www.youtube.com/watch?v=8Xs_1QCyP...
You will need suction cups:
Heavy-Duty Suction Cups (Pair)
and a Torx screwdriver set, here's what I use:
[verlinktes Produkt fehlt oder ist deaktiviert: IF145-022]
LED Startup Sequence
LED #1 = Power available.
If no LED is visible:
• Verify AC source
• Verify known-good AC cable is connected
• Verify cable connection between AC inlet and power supply
• Verify cable connection between power supply and logic board
• Verify power supply
LED #1 + LED #2 = Power available, and system is powered on.
If second LED is not visible when power button is pressed:
• Verify power button connection to logic board
• Verify power button functionality
• Verify logic board
LED #1 + LED #2 + LED #3 = Power available, system is powered on, and video card found.
If third LED is not visible after power on:
• Verify that MXM video card is seated properly
LED #1 + LED #2 + LED #3 + LED #4 = Power available, system is powered on, video card found, and internal LCD found.
If fourth LED is not visible after power on:
• Verify cable connections between LCD panel and logic board
• Inspect LCD display cables for cable damage
• Verify external video functionality, and according to result check the following items:
-If external display works then verify/replace LED backlight board
-If external display works then verify/replace LCD panel
-If external display does not work verify/replace logic board
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
7
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
4 Kommentare
There's really not enough information to give you a diagnosis yet. Can you give us a history of the problems you've had with this machine. What were the symptoms at the onset of this problem?
von mayer
Unfortunately there is not much more to say.
Pressing the power button gives the above effect. You hear the HD spinning up and the Superdrive initializing. Than it simply powers off again by itself. The screen just stays black.
Only thing I can add as history is that the system run 24x7 as file and print server for a small workgroup.
Its unclear why it switched off in the first place. Fact is that it no longer switches on :-(
von diddl14
I had it repaired. Initially they only changed the logicboard, than, after it happened again the next day, also the powersupply was replaced. I was told the SMC on the logic-board was defect. Does that make sense?
von diddl14
It means they had no idea of what the problem was and tried to baffle you with BS. Does it work?
von mayer
