Zum Hauptinhalt wechseln
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
966 Fragen Alle anzeigen
Toshiba Satellite L655D-S5164 fan makes a lot of noise. How to replace
My Toshiba Satellite L655D - S5164 fan is making a lot of noise and heat. Does it need to be replaced?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Hi here is a link to an article on removing and replacing the fan in your computer. Video and writeup. Hope it helps.
http://www.laptopinventory.com/LaptopInv...
War diese Antwort hilfreich?
Bewertung 1
I'm not quite sure, but I recommend getting it checked out, possibly at Best Buy? they have a place where technicians can check it out. One of my HP laptops has been making noise for about a year but since I haven't gotten it checked out yet because I got a new one a while back
Bewertung 0
sometimes you will not required to replace fan. after air blow blocked by dust temperature getting increases and fan controller release the order to speed up fan's RPM to cool down the system. just clean the heat sink and fan blades. noise will be decreases otherwise you have to change the cooler
Bewertung 0
I forget my desktop password
Bewertung 0
1 Kommentar:
I need help to fix it
von
Antwort hinzufügen
RodR wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,069
