replacing the HDD with an SSD
Is it possible to replace the HDD with an SSD on my HP G71?
Ist dies eine gute Frage?
Yes you can.
You'll get some performance improvement after SSD replacement as the systems CPU & memory will limit you. You will gain more run time using the laptop in battery mode, than running with a HDD.
Modern SSD's come with auto sensing SATA III (6.0 Gb/s) interfaces. Your systems chip set only supports SATA I (1.5 Gb/s). The SSD will sense this and run at SATA I (1.5 Gb/s) speed.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 780
